highway76
- 222S
BLUF: You have to remove the swim seat bracket for it to fit, something I hadnt seen anywhere online.
Boys, kinda pissed on this one. Picked up a 23 222S last summer. I did a lot of research on the Yamaha wakebooster, finally picked up the one specifically for the 22 ft model, and you cant use it without removing the swim up seat mount. Everything I read said "No tools", no drilling etc. This simply isnt the case if you have a 22 ft Yamaha. The instructions say "For best results remove the swim up seat bracket". How is that no tools, simple installation? Its not for best results, you literally cant install with the bracket in place. And it seems every 22 ft model has these brackets (minus the xd/xe because they have integrated wakebooster panels).
So heres my point:
It looks like the wakebooster would fit if you either moved the swim up seat bracket towards the bow about 2 inches, or notched the end of the booster to fit around it. Why would Yamaha market a wakebooster specifically for the 23 and up model year, "easy no tools install .1 hr", but you have to remove through hull bolts and re-silicone them if want to use it? I thinks its essentially the 21 ft model, which to my knowledge didnt come standard with brackets.
This also means there is no switching of the sides unless you remove both brackets.
So heres my point:
