Wall of shame
Surprisingly, I’ve only managed three on this list so far and none of the positive ones.
Checklists, checklists, checklists......
1,2,6,8,9,12 but number 14 more times than I can count?
If you leave a cove and your anchor is still down how many points is that? (Tied up to other boats and just dropped in, not set). Asking for a friend...Also I saw a guy do it last weekend and his bow ladder was also down, so my “friend” felt a little better. Of course the friend yelled to the guy and let him know before he got to far. The “friend” actually got up to 20 before realizing his own mistake. There may have been offspring tubing at the time.??‍♂️ This has to be big points.
Been boating a long long time. Not scoring to well! Anybody got a higher score?
My accomplishments so far in recent memory
  1. Launch boat with stern tie-downs still attached - Completed (2020 season) - 25 pts
  2. Launch boat with bow security chain still attached - Completed (2019 season) - 15 pts
  3. Launch boat with engine jet port plugs unsecured - Completed (2019 season) - 15 pts
  4. Hitting sand bar or bottom of waterway, requiring 'manual' push assistance - (Completed 2020 season) 75 pts
  5. Lose a hat or towel while underway (passengers count) - 5 pts
To-Do List (updated with contributions)
  1. Launch boat with drain plug removed - 50 pts
  2. Launch boat with dead battery - 25 pts
  3. Launch boat without keys available - 100 pts
  4. Launch boat without gas - 75 pts?
  5. Launch boat with strap still attached - 15 pts
  6. Off-center (not aligned on bunks) approach, requiring full reverse off and back on - 50 pts
  7. Unintentionally hitting any stationary object in water (dock, buoy, piling, etc) - 100 pts
  8. Mis-throttling causing passenger fall - 50 pts
  9. Sucking up debris in to jets, causing intervention - 50 pts
  10. Running out of battery while on water; due to music - 150 pts
  11. Running out of fuel while out on water - 250 pts
  12. Driving around all day with fenders on - 100 pts courtesy of @Julian
  13. Launch without cooler full of <insert beer...uh...favorite beverage here> - 1000 pts courtesy of @Julian
  14. Get laid while boating MINUS 1000 pts courtesy of @Julian
  15. Running into Truck or Trailer while you're in the water.... 500 points courtesy of @jetboatjay <<< Editors note: This should be worth more IMO.
  16. Hitting a parked vehicle with your trailer in the parking lot - 500 points courtesy of @Julian
  17. Hitting your own parked vehicle with your trailer in the parking lot - 1000 points courtesy of @Julian
Over confident, with piloting boats leads to driving truck in reverse and takes out neighbor’s mailbox. Result mailbox uprooted and crushed, did not go down without a fight though, tail lense busted. $40.00 to fix mailbox + $75.00 for replacement tail lense, embarrassment priceless!
Wait, were you trailering the boat when you hit the mailbox? With boat 200 pts, without boat 500 pts!
Does it have reverse camera? If so add another 500 pts. If it also has object warning, add another 250.
Yes, I learned the hard way, that if you make contact with the solely the lense , basically on an angle, the sensor will remain silent. You hardly feel a jolt and only hear a crunch. Followed by expletives. What I needed was a navigation system that was equipped with a AIS system.
