Sccala
- Westerly, RI
- 242 Limited S E-Series
Hi All. It’s been a while since I’ve used this forum but I wanted to come to pick some brains. I have a 2011 242 limited. Boat has run great the 3 years we’ve had it. About a month ago though, the starboard engine would flutter every 5-10 seconds, and it will no longer tach over 6000rpm….which is honestly enough, but knowing it won’t go any more doesn’t sit well with me. This happened out of the blue. One day it was running fine. The very next day…it started happening almost right away (we keep our boat in a slip) I thought maybe bad spark plugs, so I changed them. However, two of the old ones had water on them when I removed them. How could water get in the cylinder? And also, how do I get rid of it? Is it a big issue? The boat runs, but it I don’t like knowing that there’s something up with two of the cylinders having an undisclosed quantity of water or condensation in the cylinder head. ?. Any thoughts?
Thanks
Steve
Thanks
Steve
