Mike Gilmore
- NRV, VA
- Limited S
Hi All. I've done a quick (is 2 hours quick?) search on other threads and found some possible ideas to check, but I'd like to describe the problem I had yesterday to see if there are any I've overlooked. We were on the water 5 days ago, with no issues. Returned home, raised our 2008 232 HO Ltd on our boat lift and there it stayed until yesterday's mis-adventure.
In prepping the boat, I noticed 2-3 inches of standing water in the engine compartment. Unusual, but not unheard of as the stern faces to weather and rain has gotten into the compartment in the past--usually not this much tho. We left the dock, bilge pump gurgling, and made way at low throttle for approx 100 yds before accelerating. The port engine sounded odd immediately and wouldn't hold its revs (eg, it immediately dropped 1000-2000 revs when I let go of the throttle). I also noticed the port engine pee holes were not flowing. Killed the engines, and the bilge pump reactivated. Opened the engine compartment to see another 2-3 inches of water. Wife checked and saw the port engine clean out plug had blown. We re-inserted the plug and started the port engine at idle with the engine hatch open. Noticed a steady flow of water & bubbly froth emanating from a spot aft of the engine near the hull (I couldn't actually see it cause the space is tight). We moved the throttle to the first forward indent and the water increased, at which point we closed everything and returned to dock on the starboard engine alone.
I didn't think to check the water temp of the water in the engine compartment, but I'll do that when I work on the boat this coming weekend. Didn't see any oily residue either, and the water was clear. Based on what I've read in other threads, the most likely culprit seems to be a leak in the cooling hose, or the hose (or clamp) came loose? But the blown clean out plug puzzles me. Could the two issues be related? Or, does the blown clean out plug imply a different problem than a cooling hose leak? Any thoughts/suggestions would be greatly appreciated.
Edit: while watching the MR-1 cooling system video by 1960buckbuck, I realize I made a mistake above. The two aft pee holes were functioning, while the two forward pee holes were not.
