Water in my engine!
Gsidauy
Hi Guys,
Owning my boat for over 5 years I made a rocky mistake... When I was flushing the engine I accidentally left the hose connected with water running through my engine for over 15 minutes and I did not start the engine during all that time. Now I cannot turn it on... How do I drain the water?
Thanks for your help
Beachbummer
Houston TX
Take the spark plugs off, and crank it with no lanyard connected. If you are lucky and broke nothing, after you do this until no water comes out, then reinstall plugs, it will start.
If it starts, then run it like you stole it for an hour or so, to evaporate all the water from where is not supposed to be.
Best of luck. Do not delay.
Seadeals
Greenville, South Carolina
Yep, as long as you didn’t try to start it with water inside, pulling the plugs and turning it over with the lanyard out (no spark) will have the pistons pumping the water out of the cylinders. I might shoot some fogging oil into each cylinder while they are open too. The best medicine will be running it at higher rpms for extended time to evaporate it all out; but only if you can get it on the water (not on the hose). “I screwed up, Honey...mandatory lake day tomorrow!” I might have used that before 🤫
justason
SWAG Forum Lead
Same thing here. Took me a few tries to get it dry enough to kick so i put my shop vac over the spark plug holes while crankin to help evac as much moisture as possible. Then ran it like I stole it as beachbummer says
Gym
Falmouth, MA (Cape Cod)
I would only run the engine for a minute or so. Then shut down and check the oil for water. If it's milky, change the oil. Repeat this process until the oil appears clean.
Brad_Ct
Alva Fl
I agree with Jim, bought a non running boat last year and just got one engine running. Oil looked fine until after I got it running then it was milky from water in the oil. Took 14 quarts of oil and 3 filters to clear the water out.
