TiMaH
- Ancaster ON, Canada
- SX
Hey JBers..... hoping some experience can help me out here.....
So took my 2016 SX190 out to a perch derby...... blah blah blah......no issues, no bilge came on, no rain, no accumulation of water - as we were fishing....
Came home and flushed the engine with fresh water, (engine/water - water/engine), drained engine of remaining water with revs for 15-20 secs......... took out the single aft plug, both engine plugs, ski locker and fuel plug. Cleaned out normal gunk from the anchor locker (dissolvable) and hosed the anchor locker with fresh water which drains into the ski - then fuel - then engine compartment..... I think !!!
Tilted the trailer as high as it could go to drain all water.
I completely drained, wiped down and soak up all water in the ski locker.
Engine compartment had about 5-6 cups of water at bilge area. So I soaked that up.
Fuel comp had about 4-5 cups of water that wouldnt drain so I soaked that up as well.
Bilge worked fine on multiple occasions as I cleaned the interior hard fiberglass flooring.....
I even forced high(ish) pressure hose water into anchor comp and ski locker thinking maybe some left over gunk.....
Heres the issue as I see it.....I come home today after work and found water in the ski locker area (no rain - boat in driveway)
Another 5 - 6 cups off water in the engine compartment. Did not check the fuel comp.....
I dont get it...... Id very much appreciate being led down the path on this one....
Thanx M8tys
TiMaH
Thanx M8tys
TiMaH
