Wet Sound Equalizer Mic
webbug
The the mic volume is very low, everything else works and sounds high.
It's not even loud enough for the inside boat
Following.
I have the same issue on mine and haven been able to solve.
The first several trips it was plenty loud and had feedback issues once in a while. I suspect the mike got wet or something or concerned the feedback may have damaged something.
Hoping someone else has solved this or has suggestions.
Did you ever get this fixed?? I still have the same issue...
