Wet sounds led connections
toddgray519
I have a wet sounds set up want to know what do I need to connect my rgb wire to each speaker (I see a lot of stuff on Amazon but not rgb to rgb)
also I have a 222x are the 2 tower speakers pre wired for LEDs like the rest?
I’m going to pull one of my speakers sometime this week and see if I can figure out if mine are rgb compatible and what I need. I’ll let you know what I find out.
Ok thanks I appreciate it
4 pin connectors. WetSounds has them or you can find similar on Amazon
