Justin Turner
- Fort Worth, TX, 76123
- Glastron
- GTS
I have a Glastron GTS-207. I tried the wake wedge without ballast and it was a fail. I have 2250# of ballast on the way but need to eliminate the jet wash. I have read through the "mud flap" idea thread and then stumbled onto this. Can't remember what boat it is on. Anyway here is my idea.
Replace the swim platform bracket (because mine is bent anyway) with another bracket that will hold my swim deck and this "blade". I will make it slotted vertically so it can be moved up and down, depending on speed and what i'm doing, but it will stay on the boat. I am thinking it will have dedicated positions with spring loaded "latches" to hold it in place. They will be oblong latches as to hold it in the dedicated positions.
My the top of my jet is at 14" from the bottom of my swim deck and the bottom of the jet is 17 1/2" from the bottom of the swim deck so I am thinking I will make positions from 13" - 16" or so as to not blow it off and/or rip the bolts out of the transom.
Anyway, please send me your thoughts. I am by far no mechanical engineer but once I get the bracket mounted I can keep re-engineering the "blade" until it works.
Thanks for your help!
