Welcome to Jetboaters.net!
Tonight I discovered that the cheap spark plug socket from an old toolkit that I had been using would not hold on to a spark plug. So what do you guys recommend that I replace it with?
Look for a magnetic one. They are wonderful. Cheap ones have a rubber insert that 'grabs' the plug, but if that insert comes out (as it will), you are... well, where you are.
I don't use a spark plug socket. Just use a deep well socket to loosen the plug and then use the coil to go down and grab it and pull it out. Reverse that for installation.
You press it into the coil a little then feed it down the hole and finger tighten the plug by turning the coil. Pop the coil off then finish snugging the plug up with a wrench.
True, you can do it that way. But for only $15 you can have magnets.
Plus (and this is more important by far), you get to buy a tool. We all know that the main point of doing things yourself is that you have (get) to buy the toys, er, tools with which to do the job!
I use a regular plug socket with a little reversed duct tape inside it..this tends to hold the socket enough to get it into the hole. But a magnetic socket sounds like a necessary addition to the tool kit...
KD Tools 9/16" x 6" Magnetic Swivel Spark Plug Socket at Advanced Auto.
The socket also swivels around a bit which helps on those truck plugs way in the back.
