HangOutdoors
- Royal Oak, MI
Looking for some recommendations on wire brand/quality and were to purchase from. I was at West Marine and they are a bit pricey and they only had down to 6 AWG. I have read a good deal of threads here as well, so I think I got a pretty decent handle on the actually wiring, routing and wiring protection and what others have done. I take a lot of inspiration off of @Julian Electronics build.
Part 1: Choosing the Correct Wire Size for a DC Circuit - Blue Sea Systems
Here is what I am sourcing wire for: If I am understanding the charts correctly (please correct me if I am wrong), you calculate circuit as double the run to determine gauge.
I am also using these near the batteries.
Amazon.com: YMHTD 100A Reset Fuse 20-150AMP Inline Circuit Breaker Reset Fuse Holder for Car Audio Marine Boat Inverter Replace Fuses 12V-24V DC Breaker Switch Overload Protection Fuse: Automotive
Amazon.com: Blue Sea Systems 150 Amp Common BusBar with 4 studs and a cover, 2307: Sports & Outdoors
For Trolling motor
Amazon.com: Minn Kota 1865106 MKR-19 Waterproof Circuit Breaker Marine Motor Accessory, 60 Amps: Sports & Outdoors
Amazon.com : Minn Kota 1865128 MKR-26 Freshwater and Saltwater Motor Plug and Receptacle Marine Battery Accessory : Sports & Outdoors
And These
Amazon.com: Blue Sea Systems 6 Circuit Blade Fuse Block With Negative Bus 100 Amp Max Per Block 30 Per Circuit: Automotive
Was looking around Amazon, and a bunch of different choices. Any advice would be greatly appreciated.
- 20' run from Battery to Blue Seas Fuse Block under helm (Rating 100 amp). So it looks like 2AWG. (Chart Plotter, Trim Tabs, USB, VHF, etc.)
- 15' run from Trolling Motor plug to Battery Compartment (Rating 60 amp). 6AWG (Minn Kota Terrova 24v #80 thrust on bow).
- 10' run from Battery to Blue Seas Fuse Block in Port Compartment (Rating 100 amp). 4 AWG (USB, Vapor alarm, tablet and additional LED Lighting, etc.)
For Trolling motor
And These
