Wow. The amount of help / knowledge in this forum is simply mind blowing. Too many people eager to lend a hand to newbies like me. Thank you so much guys. Briefly this is what I have in mind..
1. 4 Kicker KM654LCW LED speakers to replace the stock speakers on my 2010 AR240. I have already replaced the speakers but did not connect the LED wiring as I have no clue on what wire to buy to connect (or) where to connect it to. For example how will the wire from the back speakers be routed all the way to the HU to be hooked up to a switch?
2. I need to replace the stock HU radio as it is 6 years old. I am thinking of Sony MEXM100BT 160W RMS Marine CD Receiver with Bluetooth for the simple reason it comes with an inbuilt amp and I do not need to muck around with installing a separate amp. If I have some idea on how to do this, then I can get separate radio and amp and not go for a compromising solution.
3. Install a subwoofer. Again doing research on whether to go with a powered sub with its own inbuilt amp (or) separate sub and amp. If separate sub, what will be the ideal position to install in the boat?
4. Planning to add 2 Kicker Marine KMTED enclosures ( the twins ) with Kicker LED speakers for a total of 4 speakers on the tower. This is driven by budget reasons and the fact I do not need ear-blasting sound.
5. Simple LED lights strategically placed inside the boat, instead of LED strips.
6. Underwater LED lights ( optional ). Do I need to cut into the Hull to install these lights (or) get them installed?
I currently have a dual battery in my boat. Will that be sufficient to run the sound system with the LEDs ?
@Pauly B . Very impressed with your build thread. I would love to talk to you sometime about your mods and if you might be able to help me to realize my mods in a separate pm. My boat is parked in Woodbridge and I am a frequent visitor there.
Below is a picture of my toy.
