Geiger41
- Egg Harbor Township NJ
- Boatless
- NA
- Other
- NA
Here are some pictures. As you can see, you CANNOT see the led's from normal eye level whether seated or standing..you can see them obviously when squatted down. I placed them directly under the bottom of the cushions. this gives maximum brightness and the full effect of the led's. As far as the connectors the one pic is how the whole setup is wired, simply connect and go....you can connect as many led strips side by side OR you can do one, then an extension cable then another one. Any combo you want basically. I have back to back led's in some areas and single led's in another.
