tdonoughue
- The Woodlands, TX 77381
So, the boat is now at just over 100 hours. Last two times out, it seemed a little sluggish. Mind you, I did have more people on board than usual, but even when I was down to 2 people and 1/2 a tank of gas, it took me the span of the lake to get it up to 47 mph, WOT, 7500-8k rpm on each engine, creeping up from about 43 mph.
This evening, I did the obvious thing (I think): I pulled the pumps for the first time. Clearance looked fine, but when I pulled them...
That was the starboard side. Port side had a nick or two, but nothing like the starboard side here. So, clearly that is bad and could be causing cavitation. Took them home (actually both sides, while I was at it) and cleaned them up with a file:
Much better. May need to replace them shortly, but this is at least worth a try (especially because the boat has a date on Saturday).
As a sidebar, while I had them here at home (and having been properly tutored by this site), I pulled the cones. As messed up as the starboard impeller was, inside the cone was pristine--picture perfect. Port side gave me this:
So, this is water intrusion. And then we get to my questions:
1) As to the cone I already pulled out the bad grease, cleaned up the gasket and will get new grease and reassemble. Does the gasket need to be replaced? Obviously I don't have one (and won't by Saturday), so if the consensus is yes, I will pull it again next week and replace that and the grease again.
2) When I pulled the pumps, here is what I had for the inside (starboard):
Port side was substantially the same--same type of wear on the ring. Same white stuff right behind the ring sporadically. Silicone in place everywhere, but not smooth (you can see it best on the left in this picture). I am pretty sure this is how it came stock. Problem? Anything else I am missing from this picture? That said, I do know there is some silicone missing from the forward end of the grate that I can replace. But that has been gone for a while without symptoms.
3) Your guess: will I need at least a new starboard impeller very, very soon? Should I replace in pairs?
Thanks in advance for all opinions. Especially those of our resident impeller-master, @swatski .
