  • Annoucing the SURFtember Surf Board Group Buy for JetBoaters.net members only Hosted by Transom Watersports now through September 30!
    BEST pricing of the season on the most popular wakesurf boards for jetboaters!
    - All in stock 2019 wakesurf boards on major discount, including the Popular Slingshot Coaster, Quantities are limited, only 15 buyer minimum
    You can dismiss this notice by clicking the "X" in the upper right corner >>>>>>
  • Announcing the 2019 Jetboat Pilot SEADEK Group Buy for JetBoaters.net members only! This is your best time to buy Seadek from JetboatPilot - you won't get a better price - the discount has now reached the maximum 30% already!
    So if you are tired of stepping on really hot snaps/carpet, or tired of that musty carpet smell - Seadeck is the best alternative out there! Get in on this now, or pay more later!
Yamaha air filters, need them?
KevJul2019
Michigan
I have a 2015 Yamaha SX192. Do I really need a air filter on my boat. I don’t see my engine getting much dirt on the water.
jEt_jAk
SoCal
Some debate on this but why remove it?
I_squared_r
NYC/Long Island
AR192
My air filter was clogged with oil and wasn’t allowing it to accelerate past 40mph 7000rpm. I removed it at the beginning of the season and have put 60 hours without issue.
buckbuck
Illinois
Have you resolved why it was soaked with oil?
I_squared_r
NYC/Long Island
AR192
I think the previous owner over filled the oil or fogged the motor incorrectly.
2kwik4u
Georgetown, IN
After seeing how well my boat ran in the very cool air one early August morning. I've been scheming on how I can get nice cool fresh DRY air into the engine. So far I've got a lot of convoluted ideas, but nothing really in the works.
I suspect there are some gains to be had from some form of "cool air intake", but have nothing to back up that statement/idea.
There are some risks of water intrusion if you get too creative with intake placement as well.
To answer the question......shouldn't be an issue, but I would keep at least some level of screen on there to keep at least the major sized bits of dirt/debris/bugs/etc out of the engine.
swatski
Saint Louis, MO
@jEt_jAk did that I think, and of course @SamCF, albeit sc it would be similar I think.
jEt_jAk
SoCal
Well I swapped the stock filter box with a CIA. Not really sure if there were any gains TBH. Not that I could notice at least. Maybe if the filter could be outside the engine compartment there would be a better result.
2kwik4u
Georgetown, IN
@jEt_jAk @swatski
I had a similar idea. Was considering using some thin wall aluminum tubing, and using the hole behind the swim platform seat backs as the intake location. I think the cool air from outside the engine compartment is key to see any gains at all.
Needs some form of splash guard just to be safe though.
Scottintexas
Corinth, TX (DFW)
for testing or diagnosing a problem, no problem,
the way my engine hatch foam insulation is disintegrating and powdering the engine bay, I wouldn't do it long term,
swatski
Saint Louis, MO
@jEt_jAk @swatski
Okay, I didn’t realize @jEt_jAk intake was still inside the engine bay, there are a couple of boats they run the intake to the outside. One issue is to insulate the intake hose/tube from the engine heat.
I’m currently more interested in upgrading the blower fans. The factory blowers are pathetic! And loud.
2kwik4u
Georgetown, IN
I’m currently more interested in upgrading the blower fans. The factory blowers are pathetic! And loud.—
Get strong enough blowers in there, and you can keep the heat down and help engine performance. I'm interested in what you find.
I agree the stock blowers are WAY too loud and don't move much air.
KevJul2019
Michigan
I was thinking if I removed the air filter I could get better performance. But in read the comments I will keep it in.
