Yamaha AR230 assistance please, again.
Benno
I was cleaning the back of the boat today but not sure if I’ve lost a grommet or plug whilst cleaning. It’s under the water line between both Jets.
Thanks in advance.
buckbuck
Texas
Isn't that your bilge drain plug? Should be a spare in your engine bay.
zipper
Boston Whaler
That is the scupper thru hull. There should be a rubber flapper (check valve) over the end to keep water from going back up the deck drain (scupper) hose. There should be a 1 1/2" / 38mm hose connecting a fitting at the cockpit floor below the engine hatch to that thru hull that runs thru the engine bay. The bilge drain is under that scupper outlet and several inches (15-20cm) forward.
Edit: If it is the plastic thru hull, refit with a S.S. scupper. Lots of information here about them being a week point and sinking boats because they are below the waterline.
Babin Farms
Lower Alabama
Looks like the scupper. Notice the 2 notches in it? , & @zipper beat me to it
Benno
Big thank you. Any idea where to purchase a new one please
zipper
Boston Whaler
Scottintexas
Corinth, TX (DFW)
You should review the link in my signature below for known issues with your year model and also the faq section has many great tips
Benno
Thank you but I can’t see the link.
Scottintexas
Corinth, TX (DFW)
Do you see any of my signature?
If you're on your phone try turning it to landscape, the link is also in the faq
zipper
Boston Whaler
Benno
Benno
Thanks for your help. It’s appreciated.
zipper
Boston Whaler
Maybe the first one shown. It needs to connect to this hose running from cockpit floor, sole, between the engines and clamp to the thru hull fitting at back of boat. Plastic thru hull fittings should not be used under water. S.S. would be better. But if you can't get it, replace with a 1 1/2" size WITH a rubber flapper over the outlet. Without it, water will flow back up the hose while going in reverse and enter the cockpit.
I still have the plastic factory thru hull and have ordered a S.S. replacement. I will be refitting my scupper in the next week. I feel lucky to have wet slipped for 3 years with this scupper and had no issues. But I am not one to "poke the bear". So I am changing it.
zipper
Boston Whaler
You Guys need a good Chandler like a West Marine store. Can you order one on line shipped to Qatar? The flapper is kind of important.
