tdonoughue
- The Woodlands, TX 77381
Yes, exactly. All around the intake. And it was exactly like the finish being half off that I noticed. All of that is going to cause turbulation in the water stream that will degrade performance. Not tragically, but little by little. Each bit will have a cumulative effect. If you pull the pump from the back, you can reach all the way up to the intake grate. Or you can pull the grate, but I would do the pump side. Then it is a lot of work with caulk and your finger, filling in the pitted areas and smoothing things out. Then do the outside of the grate--all of those bolts get filled in and smoothed over. And I would try a thin layer to try to smooth out the finish issues. That may not last, but any bit you get will make your speed and acceleration better.
