Williamsjetboat
- LS
Purchased my first jet boat a month ago and have been trying to figure this out since I first took it out
Starboard motor starts well with little to no choke, Port engine needs choke out whole way and needs gas to start, much harder to start then port motor. Once out with both motors running right one will stall almost like being shut off, starts right back up but will repeat problem any time it’s given gas or sits in idle more then 1 minute. 2 out of 3 sparks plugs will foul after trying to restart, problem with spark plugs seems to repeat itself as I’ve changed them 3 times. Original owner put an extra fuel pump to this motor because he had similar problem as he thinks it was starving for fuel but I eliminated this fuel pump after carb rebuild because I felt it was no longer needed
-What I’ve already done to try and fix
1. Changed spark plugs. Spark test came back good
2.Compression check (60 to 1 all cylinders) matches starboard engine
3. Rebuilt carbs
4. New fuel and oil lines/filters
5.New coil packs (All 3)
Really lost at this point and any tips or ideas are appreciated, next up on list to change is to run a hotter spark plug gonna go from an 8 to a 10 and try and switch ignition kill switches on back by cleanout ports
View attachment 99862View attachment 99864
3. Rebuilt carbs
