Bondski
@BondsGarage, I own and work on Seadoo's. I am new to Yamaha engines over the last few years and in trying to help a close friend with his 2007 AR230 have found myself learning a bit. First engine failure on his AR 230 was due to the cooling jacket corrosion described in the forums here. So we installed an SBT engine ....3 replacements ago. All failed for various mechanical reasons and all had low oil pressure after the engines warmed up. Why?
I am now testing engine 4, which was put into a 2006 Yamaha FX cruiser I'm now building and own, so that we could use the doner engine for his AR 230. He has had ZERO issues since we installed the old factory Yamaha doner engine in May. I had good luck with SBT on Seadoo 2 stroke and 4-tech engines.... but not this darn Yamaha MR1.
Now I'm left with getting this jet ski functional, yet it too also now suffers from low oil pressure after the engine warms up (zero oil pressure warmed up on idle). Intentionally high SBT bearing clearance? Dunno, but I plan to find out even if this engine which is now out of warranty gets pulled and disassembled to learn and offer warnings or solutions to others.
Using this forum, I have learned about addition of an oil pressure sensor on the MR1 (Great idea!) I have some video of doing this.
This first video is about adding the oil pressure and temperature sensors. Oil pressure decays at idle RPM. Oil temperature on this particular engine design is VERY hot, which increases the pressure decay. (To combat oil pressure loss SBT even recommended using 20w-50 oil to one of their clients, as you can find in a post online) Unless you add additional sensors to read live pressure and temp, you can only trust temperature and pressure switches (On / Off) provided by the Yamaha OEM to understand operating health. It also appears that Yamaha ECU logic ignores oil pressure below a certain RPM? So why exactly do SBT clone engines of the MR1 have low oil pressure so often reported? We'll Im trying to test and figure this out....Future testing will be done to try to understand all of this, with my new installed sensors. And "maybe" an engine tear down?
Just sharing this, you jet boaters with MR1's might get some info out of these crappy video's I'm trying to make! But really, trying to share info with you and I plan to add more detail soon as we test the SBT against stock Yamaha engines used in my buddies jet-boat.
