terrymargate
- Jet Ski
- Other
I have a 2009 VX110 jetski
Runs fine except more often than not the engine overheat beep will start the moment the ski starts. Sometimes I turn the ski off for few seconds, restart and all is fine, could run for 5 mins or 30 mins before beeping starts again
Runs fine, even with the beeping so I'm guessing its a dodgy sensor
I read that this engine has either 2 or 3 temp sensors, can anyone advise which one I should try changing first and if they are difficult to get to (I did unplug the obvious one on top of the engine, temporarily, made no difference)
also, would the SDS diagnostic software be able to identify which sensor was causing the problem? Is so I will invest in it instead of randomly changing sensors
all advice gratefully received
