Factory Speedometer Calibration
BrandonC_OK
Claremore, OK
Performing a bit of preseason work on my 2005 AR230. I pulled the panel of gages off the dash and behind the speedometer I found what appears to be a calibration dial. I haven’t seen any posts on that here so I thought I’d share a pic. My speedometer works fine, just off 20% or so.
drewkaree
West Allis & Fremont, WI
Have you tried your hand at trying to get it to read more accurately, or does that have to wait for warmer weather?
buckbuck
Texas
That is interesting. Does your boat have a paddlewheel?
buckbuck
Texas
I will have to look at mine. However, just for information, as my speedo is nearly dead accurate.
BrandonC_OK
Claremore, OK
Confirmed! Took the boat out yesterday and used a GPS speedometer app on my phone to see what my actual speed was. Holding steady at 31 mph, I turned the knob shown above counter clockwise and the speedometer slowly dropped from 37 to 31 mph.
Full speed at 43 mph matched perfectly. I had to make a few adjustments to get 20 mph to match up but it works perfectly now throughout the range of speeds.
I never noticed before but turning the boat throws the speed off quite a bit. A left turn increases and a right turn decreases. Makes sense since the paddle wheel is on the starrboard side.
