Retractable Transom Straps
1BadTundra
212X
Who all us using these bolt-on, retractable transom straps? What brand are you using, and what size?
What is the load capacity and what is the break strength? Most importantly, how do you like them?
AZMark
Phoenix, AZ
I use boat buckles. The buckles themselves are great.
The stainless bolt and nut they provide do not work well and require lubrication to install. Mine galled and completely seized up when putting them on. I had to cut one off and get new bolts - they sent me a second set for free. I’ve read about others having the same problem with the hardware.
jthackman
DFW
my trailer came with these fulton buckles attached and they work well. i figured they were standard on the shorelander trailers...but maybe these were a dealer add-on? my boat also came with a different bow-roller, not the standard dull yellow one i've seen (not a stoltz either)...
Amazon.com
HangOutdoors
Royal Oak, MI
Get the Stainless Steel Ones. Boat Buckles are fantastic.
suke
Holly Springs, NC
I have the stainless steel boat buckle brand as well. I read the reviews before I bought them about the hardware. I didn't even bother with it. Tossed it in the parts bin and went and bought stainless hardware from Ace.
drewkaree
West Allis & Fremont, WI
Boat buckles, stainless. Never had a problem with the hardware that I can recall, but it's been a few years since they were installed. TBH, these are straps to hold the boat in position on the trailer. They're not magic, if the boat wants to fly off due to forces unforseen, it's going to happen. What I can say is that when you forget that you've got them on, or you trust the wife to have removed them, they hold your boat on the trailer like nobody's business to the point that throttle is the final indicator that they're still on and doing their job. Or so I've heard...from a friend who did this...never happened to me, of course...#facepalm
DiggerPA
195S
I installed Boat Buckles Stainless Steel, and I love them. But had the same bolt issue where I had to cut one off as it seized half way on. Went to Home Depot and purchased all stainless hardware.
bubbasuwannee
NC
I installed these. The factory mounting points didn't work so well, so I drilled holes on the underside of the trailer frame to mount them so they head straight back to the tie downs. Also grabbed some different bolts. They work very well.
Amazon.com
drewkaree
Something that just came to mind after looking at @bubbasuwannee's link, I can't tell about the quality of the bolts used, but you can track down some info on the web about how bolts are graded. Grab yourself some Grade 8 bolts to use on these things. I don't know if they even make stainless in Grade 8, but using a Nylock nut should aid in removal if you end up wanting/needing to replace them later.
Sherwood
I love them. They help me get the boat centered if it ends up on the fender.
1BadTundra
212X
Thanks for the input... Stainless Steel 2" BoatBuckles it is..
1BadTundra
212X
So, I went to Amazon and found these. I've had great luck with Rhino USA products in the past, so figured I'd give these a try. These are well built parts, and lifetime warranty, We tore a strap once on a trail, sent them a pic, no questions asked, they sent out a new one. It was a buddy's fault it tore, the way he rigged it, and they replaced it anyway.
Babin Farms
Lower Alabama
It doesn’t look like they’re stainless but as long as the warranty holds I guess that’s up to you. Mine are some off brand non-stainless and they’ve held up a few years so far with no issues. I rinse them after every use and spray some wd40 on them after they dry.
1BadTundra
212X
Yea, I found the stainless ones after I fitted these. I am a fan of WD40, and a believer I powder coated finishes... Hopefully they hold up.
