Babin Farms
- Lower Alabama
That's closed cell foam, from the looks of it. If that's the case, not the huge headache of open cell, and would be a help in this use. Still no reason not to try to keep the water on the outside thoughI thought these were not loaded with foam.
This is good motivation to try again to fix those annoying little leaks that result in a few gallons coming out when I pull the drain plug.
Not sure if you're just scrapping the hull, but if so, how about cutting it open around the swim locker to get a look at what that area looks like?I finished gutting the 2017 ar240 today. Also drilled the bow under the waterline. No foam whatsoever. The material there is about a 1/2 inch thick. There is no foam in the rest of the hull or between two hulls either other than that lining the engine compartment.
The hole i drilled into the bow area with a 5” hole saw is just under the front of the swim locker. You can see the bottom of the inner hull / swim locker in the pic and the resulting plug has some of the adhesive / fiberglass resin that is between it and the bottom of the inner hull. Not pictured is the smaller 1/2 inch hole that I drilled at the lowest point or the keel / centerline a few feet back. I drilled this hole to drain any water that may have pooled in that area. Like the bigger hole there is nothing between the inner and outer hulls but air and maybe some residual fiberglass resin, no foam or anything of interest to see, at least not in this model/model year.Not sure if you're just scrapping the hull, but if so, how about cutting it open around the swim locker to get a look at what that area looks like?
Supposedly little area for drainage under there, so if water gets in the hull enough to fill that up (and possibly/probably the swim locker), it's also super slow to allow it out, making it seem like you've got water in there. I'd be interested in seeing what it looks like, if you're up to the task, and would be so kind.
I think the excess water in the bilge is from the low point of the outer hull which is under the ski / floor locker. That is water pools there and unless the boat is trailered or stored at a significant incline it does not drain into the rear where the bilge pump is. I suspected and verified this years ago so now at the start of each off season, I pull the boat onto my driveway now first to let the water under the ski locker drain towards the rear area of the bilge where the bilge pump and drain plug are located to get as much water out of the boat as possible before putting it away for the off season.So, more info about why I still have water in the bilge after a week out of the water
I was hoping there might be something blocking the area you showed. You may be correct, on that model, or 24' in general, there might be more room. I recall someone putting an inspection camera down into the drain hole in the ski locker and finding tight clearances or at least something that they suspected was slowing the drainage in that area. I've got mine on a trailer, and I have backed my boat into the ditch while on the trailer, and there was still water coming out. This was in the past, and I don't know if I still have the problem, as I've addressed the larger issues, so this may not concern me anymore, but others might.I think the excess water in the bilge is from the low point of the outer hull which is under the ski / floor locker. That is water pools there and unless the boat is trailered or stored at a significant incline it does not drain into the rear where the bilge pump is. I suspected and verified this years ago so now at the start of each off season, I pull the boat onto my driveway now first to let the water under the ski locker drain towards the rear area of the bilge where the bilge pump and drain plug are located to get as much water out of the boat as possible before putting it away for the off season.
