Fargo007
- Pensacola, FL
I've got trailer brake problems on my 22.I finally figured out what was going on. Somehow the Safety release bracket on the bottom of the actuator was getting "stuck." It apparantly wouldn't move even though the whole surge assembly would freely slide foward and aft.
Bottom line: If your Shorelander surge brakes stop working add checking freedom of movement on the safety release bracket below the surge assembly to the possible list of causes. Watch the Brake bleed video in post #12 above if you are not sure what I am talking about.
Wheels were almost red hot after coming home yesterday.
Left wheel was immovable when jacked up and spun. Right moves, but is impinged upon by the brake pads on the rotors.
ETA - I found the actuator - it's on the underside and can be seen through a round hole in the bottom. When the tire is spun and that is pushed aft with a flathead it activates.
When I lay off it the tire still spins but the brakes are definitely dragging on it.
It's not that. It's gotta be something with the brakes themselves being stuck like that.
