Justintroy
So title basically says what I’m after. In short, I’m the owner of a new to me ‘14 Ar192. It was only running about 35mph. I knew it should be faster. I’ve done the research and ordered a SVHO intercooler today on eBay. It was like new. It seems pretty straight forward switching that out. The double pisser outlet I’m just going to Y into that to the single on my boat. I’m also removing the ribbon and putting in a RIVA sleeve. Now my question is running the new cooling line. There no good write up on that that I could find. I see a short write up stating that I need to mill down the casting plate and tap it. Or just order the RIVA plate. But then, from there what am I supposed to do? I know drilling the hull is involved. But where do I drill at? Do I take certain measures to seal that spot if there’s wood? Do I plug the old water hose going to the intercooler? I just feel I’m missing a lot of needed info. Maybe these are dumb questions. I just want to make sure.
