ltw77
- Newport News, Va
- SS
I hope everyone is well! I noticed a few weeks ago, when I fired up the engines for the first time this year, the port engine was extra rough sounding but did run for the 5-10 seconds as usual to see that all is well. The starboard engine fired up as normal and ran smooth. I am familiar with the sound of these engines running in the driveway/garage not in the water with the hatch open. It can be disconcerting but I have gotten used to it.
I tested the engines again today before replacing the spark plugs. Everything is the same but now the port engine will not run. The cold crank sounds horrific. I feel like its metal on metal somewhere in the equation. No fault codes showing and nothing else seems to be out of order. I was thinking perhaps the wear ring could be an issue but I haven't found anything solid in my searches that tick all my boxes for the possible culprit. I did replace the spark plugs on both engines and the condition is the same. The starboard engine is good to go. Thank you in advance for any possible ideas on where to start!
ps. boat stays in garage attached to house, where it has lived happily since 2011(in case that info may shorten the possibilities)
