1.5L Rotax 4-TEC Reliability?
JeremyR
Torch Lake, MI
Chaparral
VRX
In the process of buying a 2017 Chaparral 203 VRX. It has about 43 hours on it, how long do these engines last? It's going to get serviced every season as it should so there's no question about keeping up on the maitenance. I've heard a lot of different stories about how reliable they are and am trying to get some more info.
genwrx
Houston, Tx
Glastron
GTS
If it has the supercharger it may need a rebuild, I think at 200/250 hours, I'd have to double check, I don't really remember. Other than that I haven't had any issues with my rotax. I'm around 70 hours, is probably due for an oil change but hopefully I can wait till after summer.
Nexus
Baltimore, MD
Scarab
195 ID
The latest BRP engines are "maintenance free" and claim not to need the SC's rebuilt. I'm not sure when these engines first came out, tho'.
JeremyR
Torch Lake, MI
Chaparral
VRX
Any idea about the cost of a supercharger rebuild?
BobJohnson
Highland Park, il
Chaparral
VR
Steve Risley
Lake Oconee, GA
Chaparral
VRX
We had ours rebuilt / serviced at the 100hr. Mark (thought it was 100hrs. Vs. 200hrs.) and it cost us about $1,200. Much more costly than anticipated.
JetTech72
SeaDoo
Challenger
If it's a MY2017 you should have a maintenance free supercharger. Easy way is to look under the engine plastic covers, directly on the cylinder head, if the engine model ends with AF or greater, than it's a maintenance free supercharger.
Only maintenance recommended would be change oil, filter & spark plugs in the spring before resuming boating season, then drive it like you stole it. Rotax have made more than 800000 of those 3 cylinders 1.5 liters engines since the early 2000, should be fairly reliable by now
JetTech72
SeaDoo
Challenger
I think a new Maintenance free supercharger is almost the same price, so I would replace instead of rebuilding it.
420 893 563
Paul Dufault
Englewood Florida
Scarab
255 Open ID
I am loving my 2020 255open with twin 200's. 83 hrs so far. bought it with 35hrs. Did my 50 hr. maintenance and want to understand what I should do beyond the 100hr maintenance. I am relieved to know that the supercharger is Maintenance free. However, the guy that did my 50 hr said I will need to rebuild the "water pumps" at 100. any feedback would be appreciated
hvluve
Glastron
GT
You will also need to rebuild the supercharge @200hrs.
Beachbummer
Houston TX
If you are keeping up with your pumps (pump oil changes as needed/yearly) you should not need to rebuild at 100 hours. These are easy to rebuild as there are only a few pieces that are pressed in place. I had not heard of those being rebuilt preemptively.
good_libby
Where have you been having yours sent our dor rebuild? I've looked all over for the 1.5L 4 tec 250hp supercharger rebuild vendor but haven't found one
