Seadeals
- Greenville, South Carolina
- SX
Focus on the rpm. Add the missing rpm, the speed follows.
FWIW in about 250 hours of running my boat in all kinds of conditions, I can’t think of anything changing my max rpm (Bimini up/down, full cooler/no cooler, 2 people/6 people, windshield open/closed, fresh wax/no wax) other than when I swapped out a tach that read about 500 high for a more accurate one. YDS has always confirmed max rpm right around the ECM-controlled 8000 rpm. Speed is slightly affected but my max of 43 has never been below 38 in the worst of any of those relative conditions.
RPM is about fuel, spark and air. Plugs, filters, fuel or a pump issue (debris/impeller damage or pitch mod/cavitation) are the only culprits I feel affect it. I only run ethanol-free 87 or 91 and use sea foam in every tank to keep things clean and reduce my chances for moisture buildup in the fuel. It could be possible you got bad gas; but seems like it would give you trouble at idle. Ringfree, Stabil, Seafoam, etc cAn only help and seems worth the simple $ to help troubleshoot out the gas.
On the air filters, I recommend just removing one and comparing the two engines in exactly the same conditions at the same time. If they are still both low you know it is not the filters and you don’t have to mess with the other engine.
