2000 Challenger sucked up a rock
Fiona
SeaDoo
Challenger
Hi everyone was wondering if anyone would have any ideas to help us out with this issue,
We sucked up a rock and it stalled the motor, did not know that was what happened so I tried to restart the boat and it wouldn’t start.
Took boat out of water and looked inside and it was lodged in the grate at the prop took it out then proceeded to take off the pump to look at Wear Ring and the propeller, very little damage to either one.
Went to restart the motor and it is surging and smoking a lot.
Does anyone have any ideas what could be damaged to cause this issue?
Since it's a direct drive, it locked that engine up solid. Since you probably have the Merc 240EFI or Merc Optimax engine, it was pumping fuel and oil for a moment after locking up.
It's gonna smoke and run rough for a bit. That should go away, if not, yes you may have some serious issues. I would take some time to idle it on hose, or in the water to see if it stabilizes itself.
On a similar note, do you still have the Hydro-surge grate installed that came from the factory? If so, get one of the solid grates or rock grates. The hydro surge was known to allow rocks and debris in like you experienced. Also, tines have been known to break off and lodge in the impeller too.
If you have the twin Rotax engines, than none of this info applies. But my guess is you have the Merc. Let us know what you have.
Good luck!
Thank you for the information it is the 240EFI and the original grate is what is on it. We will try running it this weekend and see how it goes.
Thanks again
Let's hope all works out. Here is a link to a very fairly priced solid tine grate.
MERCURY V6 SPORT JET SEADOO INTAKE GRATE 852962 | eBay
They Hydro Surge grate is a timebomb. If those tines break off, they will go through the pump. I lost a couple and they didn't damage my impeller. I suppose it was just like a small rock when it happened on my 240EFI.
These grates don't pop up often on Ebay, but this seems like a good price well under $100.
Good luck with the run!
