Blkrvrbart
- Sugar Sand
- Tango
Hey everybody. I bought a 2001 Tango knowing it had engine problems and figured on rebuilding the motor. The boat is in fantastic condition other than the engine problem. Pulled the motor last night, the #6 cylinder threw a rod through the block. The low oil alarm wire was disconnected, small oil tank was bone dry, and the stator to regulator wire connector bundle was fried. No oil = no dice, so that mystery is solved, but not sure what happened on the wiring. Since the block is junk, rebuilding mine is off the bench, and used motors bring almost as much as a rebuilt, I’m looking at remanufactured. So far from my research it looks like my best option for a replacement motor is Blackbird out in PA. Does anyone have different input as to what my best options are? Thanks.
