The wcm/ecu went bad in my waverunner , fx1000 cruiser (has the 998 cc mr1 140 hp motor/non - ho).Thanks. Happy to be here! I'm a complete DIYer so any trips to shops are a last resort. This Yamaha set up is still a learning experience. After a little more tinkering I think I've just about verified it to the ECU. I swapped the #3 and #4 injectors and #4 is still flooding. As a 100% confirmation, I'm going to swap the ECUs between the engines and see if the issue goes with it to the other side. Oh wait. I don't want any fuel in that oil so I may just throw a gauge on the injector lead and see if it's sending constant voltage. Hoping for a loose connection or some corrosion on a lead. Probably a long shot. Anyway, I'm looking into that CarmoUSA.com since it looks like they can repair them for about $353. Has anyone else had any luck with them? Sorry, don't want to hijack this thread but there's some really useful information here.
Thanks again,
Robert
Thanks much! Good idea!It's my understanding that a bad injector can cause the ECU short. Ohm test your injectors before running with the new ECU.
