kjr6306
- SX
Thanks GT5.
Yes, it was #31 in the diagram. It has a very small tear but I may have damaged the gasket when I was removing it. I'm pretty certain now that I have an issue with the head gasket, head, or block. Trying to figure out the timing marks now for setting the cams and crank so I can reinstall everything and have the timing right. I am reading there are timing marks on the cam gears which will help. Then I just need to mark the crank position and I should be good to go to remove the head.
I am having one issue. Is there a trick for removing the water pipe entering the head on top of the valve cover? I removed the rubber gasket and single allen bolt, but the thing won't budge!
