kjr6306
- SX
Just to confirm. I did not find a cracked cylinder wall. I found a cracked cylinder head. While it is possible for a small amount of fuel or water to pass into the oil by going past the rings the volume would be incredibly small with the majority being vaporized and pushed out the exhaust valve. The corroded exhaust manifold is just leaking water from one place where there is water to another area where there is water. The ONLY way that the water could get back up into the oil is if the engine was not running and the operator had the hose hooked up. Feasibly the same way that water could get back into the engine if you operated the boat with one of the engines not running. In that case, water is forced back up the exhaust, into the manifold and past an open exhaust valve, and into the cylinder head. As mentioned previously, it took a while to weed through most of the misinformation here to get the root cause of the problem. There are several threads on here documenting issues with water in their oil and replacing a corroded exhaust manifold did not fix the problem. Also, there is a myth that a block that has an exterior crack somehow can let water get in the oil. Also impossible based on the common location of that crack.
