2007 AR230 Decal Replacement - Can’t find...
BBastecki
Buford, GA
Does anyone know where I can buy this decal from for my 2007 Yamaha AR230 HO? It’s part number F2A-U4125-40-00. Pic attached of my decal that’s messed up I’m looking to replace.
zipper
Boston Whaler
@BBastecki I dont think you will find those graphics anywhere. Mine were beat up from one of the P.O.'s. I decided to remove all graphics below the rub rail in order to properly remove the oxidation on the gelcoat around them. And buff the hull to blend it all together. Gelcoat is not oxidized beneath them. Good luck with your search.
Beachbummer
Houston TX
I will also chime in, although unhelpfully, tell you that no stickers under the rub rail looks great on these boats !!!
If you really like the sticker, a local vinyl shop can probably make it with a picture and some measure.
BBastecki
Buford, GA
It was hard to find as all websites show the decal sold out, although I found it here after looking hard:
https://greatlakesskipper.com/yamaha-f2au412540-boat-graphics-decals-pair
Another question, how would anyone recommend removing the rest of the old decal before applying the new? Just use good off, or would that do more damage than good? Thanks for suggestions/feedback!
Beachbummer
Houston TX
Heat gun and blue cleaning pad worked the best... And by best I mean I cursed the least per minute while using this method.
