2008 212x speedometer + depth finder not working
netcourt
212X
Hi folks - thanks for this forum opportunity. I have a 'new to me' 2008 212x. Bought it from Georgia and just put it in the water at home in Ohio yesterday. When I took the drive with it prior to purchasing in February, I was told the speedometer wasn't working, so I paid a shop in Georgia to work on it. They replaced the paddlewheel speedo in the back of the hull, and supposedly tested it - was told that did the trick and the speed was registering at the panel. As you'd guess - yesterday there was zero speed registering AND my depth gauge (original factory) wasn't working properly. It's odd - when turning the battery on on both engines - the depth gauge fires up and reads the depth correctly. Then after a few seconds the readout changes to " --" and doesn't actively read the depth. So, I know it's functioning correctly at some level, but it won't stay active while boating.
I've read in a couple of places that his year/model has had issues with some speedometer gauge / depth gauge combined issues - that they're somehow interconnected. Has anybody had similar issues? I can confirm that the speedo wheel is not the problem - it was running and moving freely prior to unloading into the water. Thank you!
Russell
Round Rock, TX.
212X
You need to shim that Speedo wheel down a bit more at the far corner (tilt) at the wheel so it bites in to the water at speed.
Russell
Round Rock, TX.
212X
And I just remembered I replaced my depth gauge unit for another that reads thru the hull. I believe it was made by Faria.
zipper
Boston Whaler
The depth sounder is notorious for inaccurate or no reading. The speedometer transducer magnets in the paddle wheel fail and will not send a signal. I replaced the original speedometer and paddle wheel on our 07 with a GPS speedometer. The replacement paddlewheel I ordered did not work with a brand new speedometer and I returned it.
Babin Farms
Lower Alabama
Like this @zipper?
zipper
Boston Whaler
