2012 ar190 wiring diagram for engine start up
RyanMurphy
looking for wiring diagram for 2012 ar190. More specifically what all happens once turn the key to start the engine, there are a bunch of sensors in play also. Searching down a problem where I start the engine but it shuts off right away. If I manually operate the the throttle body I can keep it running. I am guessing it is a bad throttle level comp (tps sensor) but it could be something else (ECM or sensors) not allowing the throttle body to work. Be nice to know the order of operations with wiring diagrams if that makes sense Tha ks for any help
