Fyffe
- SX192
Hello All,
I've spent some time reading other contributors to the site and wanted to add some of my "lessons learned" of my own as well as asking for a bit of advice. Recently I fired up our rig and headed out on the water to find that the boat was hesitating and surging in RPM. This seemed to subside for the rest of the ride. Thought it was simply air in the fuel lines from changing the fuel and oil filters in the fall before storing as this was the first ride out. The next time I took the boat out, it wouldn't run up past 5,400-5,600 RPM. I thought the worst, blown supercharger, stuck fuel injector, fried ECU. Decided to get a new set of plugs before pulling them for inspection. Pulling the plugs they all appeared in good condition. Attached phot is the worst of the four replaced. No carbon buildup, appears to have clean burn, little to no electrode damage. I have not yet tested resistance. After replacing plugs with the recommend NGL LFR6A copper plugs, the boat performed beautifully. Runs consistently at 7,200-7,300 RPM WOT. Hope this may help others diagnosing similar issues with their boats.
