Luis071789
Omg, thank you so much. I take delivery of the boat on Thursday so I couldn’t even go out and look.
So if the screen is not recalibrating and the only location that it accepts touch is at the top, how do I fix that?I was able to get to the calibration screen. I think my touch-screen is dead. Gave this about 10 tries each; resetting and recalibrating. It simply will not accept inputs except at the very top edge of the screen.
This was helpful though!
I pulled screen out and cleaned it with iso alcoholI was able to get to the calibration screen. I think my touch-screen is dead. Gave this about 10 tries each; resetting and recalibrating. It simply will not accept inputs except at the very top edge of the screen.
How did it turn out?What others have reported is that the touch screen delaminates (from sun exposure) negating the resistance to "touch". I believe that's what happened to my screen (living in FL). Every recalibration it got worse until it totally stopped recognizing "touch".
During the pandemic I ordered a resistive touch TFT screen replacement (ebay China, was $17). Even though I took some measurements, t's (not an exact duplicate) about 1/8" off each dimension and the 4-wire ribbon is an inch short to reach the connector and on the wrong side of the glass (see image).
If you pull the rubber boot (weather seal) from the glass, you'll see how the glass and lcd screen are mated (glued).
My plan is to remove (unglue) the touch glass from the lcd unit (they are two different components). This is not your typical DIY fix. Not in a total rush to get this done. I'll post an after result when I get the nerve to take the next step.
For now I'm using the joystick while we're on the water.
This is fantastic news! Can't wait to try this on my screen.So bought my 2015 ar240 used and the touch screen did not work by touching had to use joystick or hard buttons for everything. Thought we would need a whole new screen but this reset fixed it.
Hold the system control button down for 5 seconds, will enter a hidden screen, scroll to touch screen with joystick, you will have 2 options. Reset screen to factory settings (I tried this and it didn't rectify prob) other options is recalibrate screen. I pushed this and it put X on screen to push (it recommend stylus I used finger) do this for every corner.
It now works, hope this can help someone
