sapperfitz
- Yelm, WA
- 242 Limited S E-Series
Hello,
I have a 2016 242 Limited S "E" with 25 hours on it. Two trips ago it developed a surging problem at idle and at around 4,000 RPM on the port engine. My top speed was also limited to 42 MPH. It seemed to me like something was stuck in my impeller, but I couldn't find anything there while I was out on the water. When I pulled the boat out of the water I found a small piece of wood wedged between the impeller and the vanes just aft. Problem solved (or so I thought). The next trip out I didn't have the idle surging, but did still have a surge at around 4,000 to 5,000 RPM but the engine would "jump" back to match the starboard engine (single lever on) at around 6,000. I suspected spark plugs but every plug looks brand new, no color at all, clean electrodes. I also pulled the jet pump and inspected the impeller and housing; everything still looks brand new except for a little surface rust on the impeller itself. Any ideas?
Thanks,
Fitz
Thanks,
Fitz
