Emilio22
- MIami, Florida
Good luck! I just did the exact same upgrade. Fun project and sounds greatupgrading the stock speakers and adding 2 mid-cabin - JL MX650 blue LED
adding JL M800/8V2 amp and JL 10IB sub
still have speaker cables and a few other odds and ends on the way
this will be a slow project for me
There are some cables you'll need to make sure are pulled back when you cut. You can access them from the compartment behind the drivers seat. You'll have to remove a panel (one screw if a remember) to see what you have to do.
Great question - I had a budget and that's what Odin from Earmark recommended, and that's how I ended up with this equipment. I think the thought was the MX650's were pretty decent and the 10" M series would fill in the low end nicely. I had originally thought about four MX7.7's and the sub, but after talking with Odin on the mid cabin speakers, I went with six 6.5" speakers and sub for a bit more. I am very happy with the mid cabin speakers. I set the bow speakers a little lower so people don't go deaf while laying up in the front.@MattFX4 & @Emilio22 - you both went with the MX speakers, but the M sub. May I ask why? I'm looking at adding a sub (or two) as well, but am not convinced (yet) of the premium price for the M version of the JL 10" sub. Your input would be appreciated
I went with the 800/8 JL amp as well (non-Marine version), but opted for the Polk MM651UM instead of the JL's. Probably more to do with the deal I got and accessibility of JL speakers at reasonable prices where I live than anything else. I'm targeting this weekend to do everything (except the subs - will just prewire for them).
thanks,
Derek
@MattFX4 i used this for my subOh ok. Holes for the additional 6.5"s aren't bad. I used a 5" hole saw and it cut the holes perfectly. Trying to figure out how I want to cut the hole for sub now. Either I pay someone to do it, it tackle myself with a jigsaw.
http://m.harborfreight.com/high-speed-metal-saw-91753.html?utm_referrer=direct/not provided
Highly recommend it with the shopvac on the other side
I bought (jigsaw) metal blades, fine cut, high number of teeth count. The larger blade had a shank that was too long to fit into the saw.Did you use blade that came with it? Or have to buy a special blade?
Thanks guys! I PM'd David, so will see what he thinks.
Derek
Mine definitely did, but I misplaced mine as well. I just cut to under 9" and marked the screw holes with a sharpieCan anyone here tell me if their m10ib5 sub came with a mounting template? I thought it did, but somehow managed to lose it if so.
I lost mine too.. I used welding wire at 1/2 diameter of the drill hole and drew it that wayCan anyone here tell me if their m10ib5 sub came with a mounting template? I thought it did, but somehow managed to lose it if so.
