IceJason
- Limited S
If the bilge was never flushed with a lot of water and/or vacuumed, when the boat was new, there is a lot of post-production debris and metal shavings that can cut up the plastic threads and damage them.I have a 2016 Yamaha 242 Limited E Series that is leaking from hull drain plug. I just replaced it with a new one and it still leaks from the bottom of the drain plug. Is anyone else having this issues, any suggestions?
