2017 255 - Starboard engine won’t start
Michael Lawley
Scarab
Hey - I’m new to the forum. Have a 2017 255 with twin 200s. Stored board for 6 months and Starboard engine won’t start. Doesn’t click or anything. I checked fuses. Pushed the little black rubber reset buttons. Nothing happened. This all happened after I had the boat detailed. They pulled the kill switch cord. I tried to start it it an got an error. Reconnected the cord and port engine started. Starboard won’t do anything. Any guidance would be helpful as shop doesn’t open until Tuesday. Boat has 48 hours in it. Tagging @ScarabMike @Ron@Scarab
Thank you,
Michael
Joatmon
Estero, FL
Scarab
255 SE
I would check to make sure you at least have power going to your starboard fuse block.
You should have 12VDC at #2 block connection when checked to ground. Connection goes directly to battery positive terminal.
With ignition on you should have 12V to the accessory relay.
Ron@Scarab
Fort Myers, Florida
Scarab
HO Impulse
Check big relay fuse un electrical box.
PapaBear
Daytona Beach
Scarab
HO Impulse
I just searched Amazon for these G8V-RH-1C7T-R-DC12... Thanks guys I ordered 2
