2018 210 FSH - Steering cable gone already
Liveto99
New York Hudson Valley
@Foobar I've been chasing cathodic protection in our boats, and have found none of the cables are bonded, nor lots of other things. I suspect that is part of the cause of the quick death of your cables. I haven't proven it out, but I grounded mine under the helm to see if it helps. Now when I put an ohm meter on the cables at the back of the boat to the anode, I get 0 ohms. This should help protect the cables via the anode sacrifice.
How are the grounded cables and stuff?
Frank Marshall
Nevada City, CA
I recently did a 100 hr service at 120 hrs. During the service I forced oil through the thrust control cables. Although they didn't seem tight, they were even smoother afterwards, meaning there was some deterioration. Limited salt water exposure though, 3 weeks every day in brackish water, and 1 week in saltwater. I still, with many bonding tries haven't gotten my boat to 0.8 volts as a fiberglass boat with aluminum jet drives should be.
highanddryinco
Denver, CO
FSH Deluxe
Ok, chalk me up for a bad steering cable as well. Unfortunately, just started a three week vacation in Destin and the boat is in the water. Hoping I can live with it for the vacation duration providing it doesn't get much worse. Only 120 hours, garage stored, always washed down and well lubed or so I thought. Guess not. Last trip out was in Lake Michigan roughly a year ago. (stupid Covid) Put lots of hours on it there with zero problems. It must not have liked sitting in the garage all winter and most of the summer.
Tom maser
FSH Deluxe
@Bruce - my bigger question is how the hell do you get that bolt off? There is almost no room in there. I am going to try that "through socket" set from Lowes. Hope it works.
Bruce I’m having the same issue, did you find a way to get that bolt off?
Foobar
Charleston, SC
I used one of those pass-thru socket sets. I believe I had to order a 7/8", 1" or 1 1/8" socket from Sears. (Sorry don't remember which, but you can measure it.)
HangOutdoors
Royal Oak, MI
