Mainah
- Chapin, SC
- Boatless
- NA
- Other
- Other
A good rule of thumb for stators on the yamaha 1.8l engines is 10 amps charging output (more is output but used up by the ecu, spark plug coils, etc). This is in the main rpm power band as idle will output less. That 10 amps rule of thumb is lower than reality but keeps the math easy and better to be low than high. As a comparative example late model Harley Davidson motorcycles output 10-13 amps total in the main rpm band with the stock magneto/stator. Small engines like those on lawn mowers, pressure washers, and generators all output about 3 amps which is more than enough to supply the spark to the coil/plug and charge small electric start batteries.
