Kevin-yyz
- 44.384469, -79.690059
- Moomba
- Other
Exactly. I have no idea how the system works and the manual is worthless. I guess I will get a six pack, get a hose an conduct some experiments with various combinations of battery on and off to see how the bilge actually works.
Until I find out conclusively I will continue to leave the house battery on since it is being topped off by the solar trickle charger.
Scoop
I had previously tested the pump with the batteries off via the test pushbutton on the bilge pump. It tested fine. Today I put a hose in and turned the water on with the batteries off. When the water was partway up the bilge pump it came on ....for about two seconds and then stopped, letting the water continue to rise. I’m also going to have to figure out proper battery setting while leaving it on the water. For now I have the house battery on and the battery charger plugged in.
I also get show 12.2v or so on the connext screen for the house battery when I know that it is almost fully charged. When I use the multimeter to test the battery is usually shows a much higher voltage than what the connext screen shows.
