2019 AR240 anchor locker and anchor recommendations
Simon
Hey y’all new to the jet boat world. Bought a 2019 AR240. Love it so far. I was wondering if anyone has a anchor recommendation for what size anchor fits the anchor locker the best. Also noticed in my drain plug that there are metal shavings I am guessing washing out from the manufacturing process.
Marvin willis
Morehead city nc
Don’t bother with the anchor locker if you want a anchor that actually holds. After years of my boat blowing away bc of the anchor not holding I bought a 13 lb Mantus. PITA to store but nothing is gonna pull it out once it’s set.
AJack
Tampa 33621
There will be more than shavings that will come from the bilge! Many comments that the Yamaha builders tend to leave construction debris and it makes it way to the drain plug. I had one of those red straws for WD-40 can come out.
AmesJainchill
Harrison Twp, MI
I was considering this for my new 242 as well. Lots of folks love the Mantus anchors and I can vouch for that also as an excellent anchor for mud/sand at in Lake St. Clair as a buddy has one for his larger cruiser and it holds amazingly compared to his stock delta. Only drawback is it won't fit in the locker on the jet boats and I'm reading many store the primary Mantus under the seats in the bow area. Didn't get a chance yet to measure the anchor locker area yet on my boat, but was considering a Fortress FX-7 (or maybe 11) based on @Bruce 's comment in this thread , depending on what will fit since I would like to use the anchor locker if possible..
buckbuck
Texas
@Simon help us understand your typical boating location. Anchoring in the Gulf is different than anchoring in a river.
Marvin willis
Morehead city nc
This is an example of the anchor I had in the locker compared to the anchor I just purchased for my backup anchor705029FD-46B8-4CE4-A313-33BF8EDF3AB3.jpeg
n1111z
Cape Coral, Florida
Does the Mantus require a length of chain or is rope sufficient?
Simon
I am in South Carolina. Some intercostal waterway and some ocean currents off the jetty’s in north myrtle beach.
Simon
Thank you. So far a twist tie and metal shavings.
Simon
I am in the intracoastal in South Carolina. Tides and switching currents.
Dean P
Florida
Chaparral
VRX
My Yamaha had 2 of these when I bought it. They are useless (for me) even with 6' of chain. Replaced with Danforths.
I did not know the Mantus does not require chain. Thx!
BigAbe75
Litchfield, IL
What is the difference between the one circled above and a Danforth? I thought that is a Danforth style?
zipper
Boston Whaler
@BigAbe75 The main difference is the lack of the sliding ring on the shank of a Danforth. Danforths are far superior to that POS. Here is more info on anchors.https://jetboaters.net/threads/best-anchor-for-florida-salt-water.17610/ or this one https://jetboaters.net/threads/best-anchor-for-sandy-bottoms.13698/
On the Yamaha I use a 8# West Marine Danforth style up front and that POS Seachoise that came with the boat out back.
On the Beneteau I use a 22# Delta Lewmar plow up front and a new 16# Danforth out back, which came as the main anchor but is undersized in any rough weather.
BigAbe75
Litchfield, IL
Ah, I couldn’t tell that from the pic. I was just looking at the shape/function of the blade that looks similar. Tks!!
Most of my anchoring is in mud and low current... I could probably just throw a big rock out with a rope on it and be fine. Lol (except for 1 or 2 trips a year to the ozarks)
Marvin willis
Morehead city nc
I had 12 ft of heavy chain attached to that, then to an additional mushroom anchor, the the rope. It held ok but I wouldn’t walk away from the boat. Pos the anchor the the left is a plow. I use to have a pic of my Mantus beside my other anchor but deleted it
Simon
Anybody find the perfect fit for that locker. 2019AR240. Getting it sprayed with line-x
Simon
Is the $185 Yamaha kit fit the AR240
tabbibus
Lake Lanier, GA
