MidnightRider
- Zumbro Falls, MN
- Malibu
- Wake
Yes. And then we will pause to clean up the VR goggles and go back to more "boating". lol.I just wonder if in 10 years we'll look back on this and still laugh
Wow!
Wow!
This is going to be interesting!
""SOLO is legal (so far) in 41 states, plus Guam, Puerto rico and the District of Columbia." These states are exempted from having a spotter on board for the SOLO Watercraft only."
So I got a chance to demo the 242x today with the new wakebooster in Person and I’m not going to lie, it simply works great! It’s a little cumbeursome to install at first but once you do it a few times I think it’ll be super straight forward.
We ran the boat empty of ballast but full of people in a straight line at 10.5 mph it it produced a big and clean wave. The wave seemed to curve further away from the boat and produced a huge transition zone along with a nice curl. I think you will all be impressed...
Yes, major redesign to provide some lateral thrust.Going back to the reverse bucket. Maybe i missed it being mentioned on another post but looking at Yamaha's website, it appears as if the bucket actually separates the nozzle in half when lowered for reverse. The current nozzles dont have that today, or am i missing something and its an optical illusion?
https://www.yamahaboats.com/globala...h-2019-v-bucket-maximum-maneuverability-1.jpg
What would be nice is to talk about some serious new ideas, things that could be helpful, since Yamaha isn't really bothering to do that anymore. Of course the problem will be trying to agree on what is helpful and not, etc.
For example, dealing with grass. For me, it's an issue. I know for other boaters, it's never an issue. I'm to the point, if I do get another boat, I am going to go back to an outboard both to solve my grass issue AND to get a proper working throttle. Either a bayboat or something like the Searay SDX 250 or 270 OB.
Some ideas I've had:
1) Add a bilge pump and pickup and tie into the cooling intake lines of each engine so that when I do clog up with grass, the engines don't overheat. At least if I enter a large patch of grass, maybe I can very very slowly idle out? Of course, that gets complicated. Can't risk that pump running if the engine is off! So the pump needs to be tied into the engine somehow to only run when it's on. 2) Maybe even add some type of engine vacuum driven valve that opens the cooling intake line? Then we'd even have automatic tow valves basically.
3) Switch to closed looped cooling? Problem there is the exhuast would still need cooling water and so while the engine might not overheat, the exhaust could?
4) Just like there are fuel flow meters, add a cooling flow meter and gauge to know the motors are getting cooling?
Even crazier ideas:
A) What prevents the motors from being spun backwards? Could there in theory be a way to turn the motors off, then press a 'clear' button that runs the starter motor backwards to flush the intake? Would the impeller design push enough water backwards if spun backwards?
B) A tapered impeller and sleeve? Somehow via something mechanical the impeller could slide along the shaft freeing up room between the impeller and sleeve for the grass to pass through?
I am sick of destroying my hands reaching down through the clearing tube. It's better than nothing, but at the same time, still really sucks that it even needs to be done at all, especially having to do it often during the day with a boat full of people watching me patiently waiting for us to get going again.
Other ideas:
C) I like the premium larger tops over the tower but I garage my boat. I custom built a 4th garage with an 8'3" door. I want to be able to walk around in the boat though when garaged and the tower is down. But that permanent metal framed top would be a killer.
D) Maybe design that top over the tower to be able to slide fwds or back? Then I could just slide it way fwd when in the garage? Would be nice to be able to slide it back when beached for more shade on the transom. Maybe it could be shaped like the bow and I just slide it off towards the front and it snaps down to the bow. Or maybe just design an integrated front and rear bimini top that can be collapsed against the tower and sell the hard framed top as a seperate add on.
E) How can we get a larger driver's side helm door to make it easier to get in there?
F) How about a layout like that SDX 250 with the side walkway and that much larger a head compartment?
G) With the typical center layout and walkway, why even bother with a walkway to 'almost' the front? We always have the bow cushion in place. I've seen some boats where the whole front is a floor at the level of the seats, and you step up right where the drivers/passenger compartments start. The Floor locker could be that much larger with two levels! It sucks getting stuff out of the floor locker that's gotten buried at the bottom.
H) I absolutely hate those ugly large tower mountered speakers. I'd like to see nicer, smaller, hidden integrated speakers. I think they did offer this once a while back but then went away. Bring it back, just better.
I) A true rear anchor locker. Right now. it's awkward cause anchor doesn't have a designated spot, and the line is always in the way. Maybe on the side with the table mount, a single door in the lower transom just for the anchor and a dedicated popup cleat right there?
J) A bow anchor locker that doesn't flood and spill over into the rest of the boat.
The searay 25 and 27' models: (of course they are that much more expensive).
@robert843, it is easy to appreciate those Sea Rays but I can not imagine giving up the comfort and enjoyment of having a swim deck without an outboard or even props intruding. The jet drive makes the experience of hanging out at the stern so much more enjoyable.
Yep. But it's also about time to furnish E-throttles (fly-by-wire) in all those boats, particularly since those already have APSs!Here is what I want for 2020. An AR240 with a tower design similar to the X series or another design so I’m not concerned about it falling. Fix the dash and let us pick our own colors similar to Axis (if you must charge more for letting the customer/dealer pick colors and get ride of the decals).
I'm with ya on that. I liked my Yamaha, but after seeing the new price increases for the 2019 models, I'm w/ @swatski & will move on to other brands. A person can buy a real boat for the price range Yamaha are getting into.Holy cow! 80k.... Geezzz..... I just don't understand the price if these things keeps going so far north. ..
hey, thanks for the post. Seriously considering a 2019 242X. Did anyone actually get out there and surf the wave to see just how much push it had?
