2019 SCARAB 195 OPEN ID - 200 hp Mystery Relay Tripping
Jackson@lake_eufaula
Scarab
195 Open ID
I bought the boat in 2019. Last summer we were dead in the water 5 times or so. A fuel pump issue (it was installed incorrectly) that I fixed were the first two times.
The rest of the shut off problems go as follows:
When the boat is driven wide open at full RPMs for 30 - 40 minutes continuous it pops a relay. Sudden stop.
A code comes up U0410. Also Sometimes (not Always) it says reverse module error.
If you let the relay cool for 20 minutes you can continue to use the boat at lower RPMs as long as you like.
Now - my boat has been at the dealership since last October.
The relay has been replaced by the dealership. They are New batteries. Fully charged with on board charger. Normal voltage showing at rest and under use.
Dealer takes the boat out this last weekend and says he CANNOT recreate the problem. Thought? Water temp could be a factor ? I am in Oklahoma city area.
I have started writing to SCARAB directly over the last few months but they are slow to respond and appear to only contact the dealer.
Dealer is now slow answering any texts.
found an older article here on the forum that I want them to check out - posted it below. any help at all would be much appreciated
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
I'm not an expert on relays, but I think most relays fail because of a short somewhere. Could it be you had some sort of short that has now been fixed when the dealer reinstalled everything? I don't see how water temperature would make a relay fail. I'm betting on a short...
Dean P
Chaparral
VRX
Hi and :Welcome: to the forum!
The part you circled is from me. What I stated was true. They did replace the eReverse module and really haven't had any issues with it since (throwing codes that is). Curious, why are you WOT for 30-40 minutes? Do you ever just cruise? I see you have no issues running at a lower speed. Maybe that's your answer. IDK
With that said, I agree with @Luc Lafreniere and found this:
"Quick update on the ereverse not working. The dealer found a faulty connection behind the gear shift/speed control next to the driver. They had to remove the panel and replace the connector and then add a strain relief. That was last week and I am happy to say it seems to have resolved the problem. "
Not sure if this will fix your problem but maybe a place to start?
Scarab
195 Open ID
I agree.
Scarab
195 Open ID
Wide open. Just returning from a day on a remote beach. Each time running full speed. In one case. Wanted to dock before dark. The other. If you must know was a bathroom emergency with a crew member.
any how. What difference does it make. All boats have a top speed. Mine just just pops a relay when I use it too long. There should be no reason a person cannot enjoy the speed of a sport boat.
I love to cruise. Cruise all day. Then quick to get home.
thank you so much for the info. I will have my dealer look into this ASAP. I hope this is the fix.
Dean P
Chaparral
VRX
Understood, found myself in those exact situations. But on the other side, running any engine at max RPMs over a long period of time pushes everything to the max and will fail. Seams when I do something always goes bad. I'm also glad to know that we can with our engines. Thx!!!
Findings shorts can be like finding a needle in a haystack. Maybe you'll get lucky 🤞! Good luck!
Scarab
195 Open ID
After continuous emails to SCARAB's website email link..... they called me today. Although they sent a tech to work on this boat back in June. somehow the work ticket case file was lost? they are starting another. They are replacing the engine harness and the reverse module and the relays and I guess anything else they can throw at it. Looks as if the service manager at my dealership has been let go as well. I think my boat is one of several he was ignoring. I hope I get to use this boat finally without ending adrift.
Dean P
Chaparral
VRX
That's great news! Please share his findings as this WILL help others. Glad they're finally doing something.
anmut
Glad your getting help, but honestly, I would've been threatening a buy back by now. I hope they get you straightened out for the next season.
