2021 212X Sub Channel on WetSounds AMP issue
CLBeerbower
Castle Rock, Co
212X
Ok, team have a quick question. Have a 2021 212XD and I ws told by a reputable stereo show that my sub channel on the wet sounds amp is dead. Sub itself check out ok, but no signal to it. Anyone else have this issue? Ideas outside of replacing the whole amp which I am guessing will cost over $1,000. Wiring also checked out ok. Really appreciate the help as I am going to assume that the Yamaha amp is not returnable once I open the box. Thanks!
How old is the amp?
It is the original amp that came with the boat. Other channels of the amp work fine. Just no signal to the subwoofer itself.
It may be warrantied by Wetsounds or Yamaha. What year boat? 2021 should be warrantied.
I didn’t think the warranty would last three years. The basic Yamaha warranty I thought was 12 months. Do you have info to the contrary? Happy to be wrong.
Would be worth contacting Wetsounds - they are usually pretty good
Good thread... I hae a 2016 2430 Vortex with the Wet SOunds system. Where does one find the amp? Stereo has power but no sound out of the speakers.
THx, Bob
I have a 2020 242X and the sub is not getting a signal, all other speakers work. I traced the wires from the sub to the lower connector on the large amp. I would like to consider adding another amp just for the sub but I do not know which wires are the sub input?
Is there a wire diagram out there for the factory 6ch amp?
