2022 25ft boat trailer jack broke
You're right, I went to my boat today and realized I didn't actually use the existing holes, but bolted it up the new jack with the supplied "U" brackets slightly forward of the original mounting holes. Fits fine though. Sorry for steering you wrong.
It’s all good I ended up just going to northern tool and picking up a 1500lb jack that’s bolts up to it using existing holes using oem parts. It works great. Just had to modify whole to be slightly larger. $65
+1 for the Arc. I ended with the 500 over the 750 though. Didn't see the need to spend the extra money.
Installed a new trailer jack, much beefier than the last one. Did not have to remove the winch stand to takeoff the old one, it’s a little tricky but you can fit a wrench in there to loosen the bolts until they come out.
I am an idiot!!
And not 2 weeks later I bent this new jack, jacking it up to change a flat near the axel, didn’t realize all the torque it would put on the front jack. I had blocks on the tires so thought there was no reason to attach it to the vehicle. This is after I changed the flat.
I am an idiot!!
Go get yourself the ARK 750 and you won't regret it. there are those whom use the ARK and then there is everyone else :)
I use a Jack stand under my tongue, anytime it is off the truck for the most part. A 6 ton I believe. Keeps the trailer steady as well.
